ArcGIS.Core.Data.Knowledge Namespace / KnowledgeGraph Class / SubmitSearch Method
The search filter to submit
Example
    SubmitSearch Method (KnowledgeGraph)
    Perform a text search on the knowledge graph using the given KnowledgeGraphSearchFilter. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Parameters
    searchFilter
    Return Value
    Exceptions
    ExceptionDescription
    searchFilter cannot be null
    searchFilter.SearchText cannot be null or empty.
    Remarks
    Addins can specify KnowledgeGraphSearchFilter.SearchText using the Apache Lucene Query Parser syntax. If a KnowledgeGraphSearchFilter.MaxRowCount is not specified then it defaults to 100. Addins should call ArcGIS.Core.Data.Realtime.RealtimeCursorBase.WaitForRowsAsync on the returned KnowledgeGraphCursor instance after submitting a search to wait for rows to be returned. If the searchFilter is null a System.ArgumentNullException will be thrown. If the searchFilter SearchText is empty or null, a System.ArgumentException will be thrown.
    Example
    Submit a Text Search
      await QueuedTask.Run(async () =>
        //and assuming you have established a connection to a knowledge graph
        //Construct a KG search filter. Search text uses Apache Lucene Query Parser
        //syntax - https://lucene.apache.org/core/2_9_4/queryparsersyntax.html
        var kg_sf = new KnowledgeGraphSearchFilter()
          SearchTarget = KnowledgeGraphNamedTypeCategory.Entity,
          SearchText = "Acme Electric Co.",
          ReturnSearchContext = true,
          MaxRowCount = 10 //Default is 100 if not specified
        //submit the search - returns a KnowledgeGraphCursor
        var e = 0;
        using (var kg_rc = kg.SubmitSearch(kg_sf))
          //wait for rows to be returned from the server
          //note the "await"...
          while (await kg_rc.WaitForRowsAsync())
            //Rows have been retrieved - process this "batch"...
            while (kg_rc.MoveNext())
              //Get the current KnowledgeGraphRow
              using (var graph_row = kg_rc.Current)
                //We are returning entities from this search
                var entity = graph_row[0] as KnowledgeGraphEntityValue;
                var entity_type = entity.GetTypeName();
                var record = new List<string>();
                //discover keys(aka "fields") dynamically via GetKeys
                foreach (var prop_name in entity.GetKeys())
                  var obj_val = entity[prop_name] ?? "null";
                  record.Add(obj_val.ToString());
                System.Diagnostics.Debug.WriteLine(
                  $"{entity_type}[{e++}] " + string.Join(", ", record));
                //or use "Process a KnowledgeGraphRow Value" snippet
                //ProcessKnowledgeGraphRowValue(entity);
          }//WaitForRowsAsync
        }//SubmitSearch
    Call WaitForRowsAsync With Cancellation
      //On the QueuedTask...
      //submit query or search to return a KnowledgeGraphCursor
      //using (var kgRowCursor = kg.SubmitQuery(kg_qf)) {
      //using (var kgRowCursor = kg.SubmitSearch(kg_sf)) {
      //"auto-cancel" after 20 seconds
      var cancel = new CancellationTokenSource(new TimeSpan(0, 0, 20));
      //catch TaskCanceledException
      try
        while (await kgRowCursor.WaitForRowsAsync(cancel.Token))
          //check for row events
          while (kgRowCursor.MoveNext())
            using (var graph_row = kgRowCursor.Current)
              //Graph row is an array, process all returned values...
              var val_count = (int)graph_row.GetCount();
              for (int i = 0; i < val_count; i++)
                var retval = graph_row[i];
                //Process row value (note: recursive)
                //See "Process a KnowledgeGraphRow Value" snippet
                ProcessKnowledgeGraphRowValue(retval);
      //Timeout expired
      catch (TaskCanceledException tce)
        //Handle cancellation as needed
      cancel.Dispose();
    Requirements
    ArcGIS Pro version: 3.2 or higher.
