ArcGIS.Core.Data.Knowledge Namespace / KnowledgeGraphCursor Class / FindKey Method
    FindKey Method
    Gets the index of the specified key. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function FindKey( _
       ByVal keyName As String _
    ) As Integer
    public int FindKey(
       string keyName
    Parameters
    keyName
    Return Value
    The index of the specified key if present in the cursor.
    Exceptions
    ExceptionDescription
    Requirements
    ArcGIS Pro version: 3.2 or higher.
