ArcGIS.Core.Data.Knowledge Namespace / KnowledgeGraphCursor Class / Current Property
Example
    Current Property (KnowledgeGraphCursor)
    Gets the current KnowledgeGraphRow in the graph row cursor.
    Syntax
    Public ReadOnly Property Current As KnowledgeGraphRow
    public KnowledgeGraphRow Current {get;}
    Remarks
    If the cursor has passed the end of the collection then null is returned. If a valid KnowledgeGraphRow is returned by this property, it should be Disposed.
    Example
    Submit a Graph Query
      await QueuedTask.Run(async () =>
        //and assuming you have established a connection to a knowledge graph
        //Construct an openCypher query - return the first 10 entities (whatever
        //they are...)
        var query = "MATCH (n) RETURN n LIMIT 10";//default limit is 100 if not specified
                                                  //other examples...
                                                  //query = "MATCH (a:Person) RETURN [a.name, a.age] ORDER BY a.age DESC LIMIT 50";
                                                  //query = "MATCH (b:Person) RETURN { Xperson: { Xname: b.name, Xage: b.age } } ORDER BY b.name DESC";
                                                  //query = "MATCH p = (c:Person)-[:HasCar]-() RETURN p ORDER BY c.name DESC";
        //Create a query filter
        //Note: OutputSpatialReference is currently ignored
        var kg_qf = new KnowledgeGraphQueryFilter()
          QueryText = query
        //Optionally - u can choose to include provenance in the results
        //(_if_ the KG has provenance - otherwise the query will fail)
        bool includeProvenanceIfPresent = KnowledgeGraphSupportsProvenance(kg);
        if (includeProvenanceIfPresent)
          //Only include if the KG has provenance
          kg_qf.ProvenanceBehavior =
              KnowledgeGraphProvenanceBehavior.Include;//default is exclude
        //submit the query - returns a KnowledgeGraphCursor
        using (var kg_rc = kg.SubmitQuery(kg_qf))
          //wait for rows to be returned from the server
          //note the "await"...
          while (await kg_rc.WaitForRowsAsync())
            //Rows have been retrieved - process this "batch"...
            while (kg_rc.MoveNext())
              //Get the current KnowledgeGraphRow
              using (var graph_row = kg_rc.Current)
                //Graph row is an array, process all returned values...
                var val_count = (int)graph_row.GetCount();
                for (int i = 0; i < val_count; i++)
                  var retval = graph_row[i];
                  //Process row value (note: recursive)
                  //See "Process a KnowledgeGraphRow Value" snippet
                  ProcessKnowledgeGraphRowValue(retval);
          }//WaitForRowsAsync
        }//SubmitQuery
    Requirements
    ArcGIS Pro version: 3.2 or higher.
