ArcGIS.Core.Data.Knowledge Namespace / KnowledgeGraphDataModel Class / GetIsArcGISManaged Method
Example
    Gets a boolean indicating whether the data in the knowledge graph is ArcGIS managed. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetIsArcGISManaged() As Boolean
    public bool GetIsArcGISManaged()
    Return Value
    Exceptions
    ExceptionDescription
    Example
    Get Data Model Properties
      await QueuedTask.Run(() =>
        //Create a connection properties
        var kg_props =
            new KnowledgeGraphConnectionProperties(new Uri(url));
        using (var kg = new KnowledgeGraph(kg_props))
          //Get the KnowledgeGraph Data Model
          using (var kg_dm = kg.GetDataModel())
            var kg_name = System.IO.Path.GetFileName(
                     System.IO.Path.GetDirectoryName(kg_props.PathOrURL.ToString()));
            System.Diagnostics.Debug.WriteLine(
              $"\r\n'{kg_name}' Datamodel:\r\n-----------------");
            var time_stamp = kg_dm.GetTimestamp();
            var sr = kg_dm.GetSpatialReference();
            System.Diagnostics.Debug.WriteLine($"Timestamp: {time_stamp}");
            System.Diagnostics.Debug.WriteLine($"Sref: {sr.Wkid}");
              $"IsStrict: {kg_dm.GetIsStrict()}");
              $"OIDPropertyName: {kg_dm.GetOIDPropertyName()}");
              $"IsArcGISManaged: {kg_dm.GetIsArcGISManaged()}");
    Requirements
    ArcGIS Pro version: 3.2 or higher.
