ArcGIS.Core.Data.Knowledge Namespace / KnowledgeGraphDataModel Class / GetOIDPropertyName Method
Example
    Gets the name of the ObjectID property for the knowledge graph. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetOIDPropertyName() As String
    public string GetOIDPropertyName()
    Return Value
    Exceptions
    ExceptionDescription
    Example
    Get Data Model Properties
      await QueuedTask.Run(() =>
        //Create a connection properties
        var kg_props =
            new KnowledgeGraphConnectionProperties(new Uri(url));
        using (var kg = new KnowledgeGraph(kg_props))
          //Get the KnowledgeGraph Data Model
          using (var kg_dm = kg.GetDataModel())
            var kg_name = System.IO.Path.GetFileName(
                     System.IO.Path.GetDirectoryName(kg_props.PathOrURL.ToString()));
            System.Diagnostics.Debug.WriteLine(
              $"\r\n'{kg_name}' Datamodel:\r\n-----------------");
            var time_stamp = kg_dm.GetTimestamp();
            var sr = kg_dm.GetSpatialReference();
            System.Diagnostics.Debug.WriteLine($"Timestamp: {time_stamp}");
            System.Diagnostics.Debug.WriteLine($"Sref: {sr.Wkid}");
              $"IsStrict: {kg_dm.GetIsStrict()}");
              $"OIDPropertyName: {kg_dm.GetOIDPropertyName()}");
              $"IsArcGISManaged: {kg_dm.GetIsArcGISManaged()}");
    Requirements
    ArcGIS Pro version: 3.2 or higher.
