Public Function GetRelationshipTypes() As IReadOnlyDictionary(Of String,KnowledgeGraphRelationshipType)
public IReadOnlyDictionary<string,KnowledgeGraphRelationshipType> GetRelationshipTypes()
| Exception | Description |
| ArcGIS.Core.CalledOnWrongThreadException | This method or property must be called within the lambda passed to QueuedTask.Run. |
await QueuedTask.Run(() =>
//Create a connection properties
var kg_props =
new KnowledgeGraphConnectionProperties(new Uri(url));
using (var kg = new KnowledgeGraph(kg_props))
//Get the KnowledgeGraph Data Model
using (var kg_dm = kg.GetDataModel())
var dict_types = kg_dm.GetRelationshipTypes();
foreach (var kvp in dict_types)
var rel_type = kvp.Value;
var role = rel_type.GetRole();
//note "name" will be the same name as the corresponding
//feature class or table in the KG's relational gdb model
var name = rel_type.GetName();
//etc.
//Get relationship end points
var end_points = rel_type.GetEndPoints();
foreach (var end_point in end_points)
System.Diagnostics.Debug.WriteLine(
$"Origin: '{end_point.GetOriginEntityTypeName()}', " +
$"Destination: '{end_point.GetDestinationEntityTypeName()}'");
var kg_props =
using (var kg_datamodel = kg.GetDataModel())
var entities = kg_datamodel.GetEntityTypes();
var relationships = kg_datamodel.GetRelationshipTypes();
var provenance = kg_datamodel.GetMetaEntityTypes();
var all_graph_types = new List<KnowledgeGraphNamedObjectType>();
all_graph_types.AddRange(entities.Values);
all_graph_types.AddRange(relationships.Values);
all_graph_types.AddRange(provenance.Values);
System.Diagnostics.Debug.WriteLine("\r\nGraph Types");
int c = 0;
foreach (var graph_type in all_graph_types)
var type_name = graph_type.GetName();
var role = graph_type.GetRole().ToString();
//equivalent to:
//var fields = featClassDef.GetFields().Select(f => f.Name).ToList();
//var field_names = string.Join(",", fields);
var props = graph_type.GetProperties().Select(p => p.Name).ToList();
var prop_names = string.Join(",", props);
System.Diagnostics.Debug.WriteLine($"[{c++}]: " +
$"{type_name}, {role}, {prop_names}");
