ArcGIS.Core.Data.Knowledge Namespace / KnowledgeGraphDataModel Class / GetSpatialReference Method
Example
    GetSpatialReference Method (KnowledgeGraphDataModel)
    Get the spatial reference for the knowledge graph. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetSpatialReference() As SpatialReference
    public SpatialReference GetSpatialReference()
    Return Value
    Exceptions
    ExceptionDescription
    Remarks
    All named object geometries must be in the spatial reference of the knowledge graph.
    Example
    Get Data Model Properties
      await QueuedTask.Run(() =>
        //Create a connection properties
        var kg_props =
            new KnowledgeGraphConnectionProperties(new Uri(url));
        using (var kg = new KnowledgeGraph(kg_props))
          //Get the KnowledgeGraph Data Model
          using (var kg_dm = kg.GetDataModel())
            var kg_name = System.IO.Path.GetFileName(
                     System.IO.Path.GetDirectoryName(kg_props.PathOrURL.ToString()));
            System.Diagnostics.Debug.WriteLine(
              $"\r\n'{kg_name}' Datamodel:\r\n-----------------");
            var time_stamp = kg_dm.GetTimestamp();
            var sr = kg_dm.GetSpatialReference();
            System.Diagnostics.Debug.WriteLine($"Timestamp: {time_stamp}");
            System.Diagnostics.Debug.WriteLine($"Sref: {sr.Wkid}");
              $"IsStrict: {kg_dm.GetIsStrict()}");
              $"OIDPropertyName: {kg_dm.GetOIDPropertyName()}");
              $"IsArcGISManaged: {kg_dm.GetIsArcGISManaged()}");
    Requirements
    ArcGIS Pro version: 3.2 or higher.
