ArcGIS.Core.Data.Knowledge Namespace / KnowledgeGraphDataModel Class / GetTimestamp Method
Example
    GetTimestamp Method (KnowledgeGraphDataModel)
    Get the timestamp indicating when the data model was last modified. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetTimestamp() As Date
    public DateTime GetTimestamp()
    Return Value
    Exceptions
    ExceptionDescription
    Example
    Get Data Model Properties
      await QueuedTask.Run(() =>
        //Create a connection properties
        var kg_props =
            new KnowledgeGraphConnectionProperties(new Uri(url));
        using (var kg = new KnowledgeGraph(kg_props))
          //Get the KnowledgeGraph Data Model
          using (var kg_dm = kg.GetDataModel())
            var kg_name = System.IO.Path.GetFileName(
                     System.IO.Path.GetDirectoryName(kg_props.PathOrURL.ToString()));
            System.Diagnostics.Debug.WriteLine(
              $"\r\n'{kg_name}' Datamodel:\r\n-----------------");
            var time_stamp = kg_dm.GetTimestamp();
            var sr = kg_dm.GetSpatialReference();
            System.Diagnostics.Debug.WriteLine($"Timestamp: {time_stamp}");
            System.Diagnostics.Debug.WriteLine($"Sref: {sr.Wkid}");
              $"IsStrict: {kg_dm.GetIsStrict()}");
              $"OIDPropertyName: {kg_dm.GetOIDPropertyName()}");
              $"IsArcGISManaged: {kg_dm.GetIsArcGISManaged()}");
    Requirements
    ArcGIS Pro version: 3.2 or higher.
