ArcGIS.Core.Data.Knowledge Namespace / KnowledgeGraphEndPoint Class / GetDestinationEntityTypeName Method
Example
    Get the destination entity type name for the end point. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public string GetDestinationEntityTypeName()
    Public Function GetDestinationEntityTypeName() As String
    Return Value
    Exceptions
    ExceptionDescription
    Example
    Get KnowledgeGraph Relationship Types
      await QueuedTask.Run(() =>
        //Create a connection properties
        var kg_props =
            new KnowledgeGraphConnectionProperties(new Uri(url));
        using (var kg = new KnowledgeGraph(kg_props))
          //Get the KnowledgeGraph Data Model
          using (var kg_dm = kg.GetDataModel())
            var dict_types = kg_dm.GetRelationshipTypes();
            foreach (var kvp in dict_types)
              var rel_type = kvp.Value;
              var role = rel_type.GetRole();
              //note "name" will be the same name as the corresponding
              //feature class or table in the KG's relational gdb model
              var name = rel_type.GetName();
              //etc.
              //Get relationship end points
              var end_points = rel_type.GetEndPoints();
              foreach (var end_point in end_points)
                System.Diagnostics.Debug.WriteLine(
                  $"Origin: '{end_point.GetOriginEntityTypeName()}', " +
                  $"Destination: '{end_point.GetDestinationEntityTypeName()}'");
    Requirements
    ArcGIS Pro version: 3.2 or higher.
