public KnowledgeGraphUUIDMethodHint GetMethodHint()
Public Function GetMethodHint() As KnowledgeGraphUUIDMethodHint
| Exception | Description |
| ArcGIS.Core.CalledOnWrongThreadException | This method or property must be called within the lambda passed to QueuedTask.Run. |
await QueuedTask.Run(() =>
//Create a connection properties
var kg_props =
new KnowledgeGraphConnectionProperties(new Uri(url));
using (var kg = new KnowledgeGraph(kg_props))
//Get the KnowledgeGraph Data Model
using (var kg_dm = kg.GetDataModel())
var kg_id_info = kg_dm.GetIdentifierInfo();
var kg_id_gen = kg_id_info.GetIdentifierGeneration();
if (kg_id_info is KnowledgeGraphNativeIdentifier kg_ni)
System.Diagnostics.Debug.WriteLine(
$"IdentifierInfo: KnowledgeGraphNativeIdentifier");
else if (kg_id_info is KnowledgeGraphUniformIdentifier kg_ui)
$"IdentifierInfo: KnowledgeGraphUniformIdentifier");
$"IdentifierName: '{kg_ui.GetIdentifierName()}'");
$"Identifier MethodHint: {kg_id_gen.GetMethodHint()}");
