ArcGIS.Core.Data.Knowledge Namespace / KnowledgeGraphIdentifierInfo Class
Members Example
    Abstract base class representing information about unique identifiers in the knowledge graph. Concrete subclasses include KnowledgeGraphNativeIdentifier and KnowledgeGraphUniformIdentifier.
    Object Model
    KnowledgeGraphIdentifierInfo ClassKnowledgeGraphIdentifierGeneration Class
    Syntax
    Public MustInherit Class KnowledgeGraphIdentifierInfo
       Inherits ArcGIS.Core.CoreObjectsBase
       Implements System.IDisposable
    public abstract class KnowledgeGraphIdentifierInfo : ArcGIS.Core.CoreObjectsBase, System.IDisposable
    Example
    Get Data Model Identifier Info
      await QueuedTask.Run(() =>
        //Create a connection properties
        var kg_props =
            new KnowledgeGraphConnectionProperties(new Uri(url));
        using (var kg = new KnowledgeGraph(kg_props))
          //Get the KnowledgeGraph Data Model
          using (var kg_dm = kg.GetDataModel())
            var kg_id_info = kg_dm.GetIdentifierInfo();
            var kg_id_gen = kg_id_info.GetIdentifierGeneration();
            if (kg_id_info is KnowledgeGraphNativeIdentifier kg_ni)
              System.Diagnostics.Debug.WriteLine(
                $"IdentifierInfo: KnowledgeGraphNativeIdentifier");
            else if (kg_id_info is KnowledgeGraphUniformIdentifier kg_ui)
                $"IdentifierInfo: KnowledgeGraphUniformIdentifier");
                $"IdentifierName: '{kg_ui.GetIdentifierName()}'");
              $"Identifier MethodHint: {kg_id_gen.GetMethodHint()}");
    Inheritance Hierarchy
    System.Object
          ArcGIS.Core.Data.Knowledge.KnowledgeGraphIdentifierInfo
             ArcGIS.Core.Data.Knowledge.KnowledgeGraphNativeIdentifier
             ArcGIS.Core.Data.Knowledge.KnowledgeGraphUniformIdentifier
    Requirements
    ArcGIS Pro version: 3.2 or higher.
