ArcGIS.Core.Data.Knowledge Namespace / KnowledgeGraphUniformIdentifier Class
Members Example
    Represents a unique identifier information object for a knowledge graph that uses a uniform property as the unique identifier for entities and relationships.
    Object Model
    KnowledgeGraphUniformIdentifier ClassKnowledgeGraphIdentifierGeneration Class
    Syntax
    Public NotInheritable Class KnowledgeGraphUniformIdentifier
       Inherits KnowledgeGraphIdentifierInfo
       Implements System.IDisposable
    public sealed class KnowledgeGraphUniformIdentifier : KnowledgeGraphIdentifierInfo, System.IDisposable
    Example
    Get Data Model Identifier Info
      await QueuedTask.Run(() =>
        //Create a connection properties
        var kg_props =
            new KnowledgeGraphConnectionProperties(new Uri(url));
        using (var kg = new KnowledgeGraph(kg_props))
          //Get the KnowledgeGraph Data Model
          using (var kg_dm = kg.GetDataModel())
            var kg_id_info = kg_dm.GetIdentifierInfo();
            var kg_id_gen = kg_id_info.GetIdentifierGeneration();
            if (kg_id_info is KnowledgeGraphNativeIdentifier kg_ni)
              System.Diagnostics.Debug.WriteLine(
                $"IdentifierInfo: KnowledgeGraphNativeIdentifier");
            else if (kg_id_info is KnowledgeGraphUniformIdentifier kg_ui)
                $"IdentifierInfo: KnowledgeGraphUniformIdentifier");
                $"IdentifierName: '{kg_ui.GetIdentifierName()}'");
              $"Identifier MethodHint: {kg_id_gen.GetMethodHint()}");
    Inheritance Hierarchy
    System.Object
       ArcGIS.Core.CoreObjectsBase
          ArcGIS.Core.Data.Knowledge.KnowledgeGraphIdentifierInfo
             ArcGIS.Core.Data.Knowledge.KnowledgeGraphUniformIdentifier
    Requirements
    ArcGIS Pro version: 3.2 or higher.
