ArcGIS.Core.Data.Knowledge Namespace / KnowledgeGraphPathValue Class / GetRelationshipCount Method
Example
    Gets the number of relationships in the path. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetRelationshipCount() As ULong
    public ulong GetRelationshipCount()
    Return Value
    Exceptions
    ExceptionDescription
    Remarks
    This will always be equal to the number of entities in the path minus one.
    Example
    Process a KnowledgeGraphRow Value
    void ProcessGraphNamedObjectValue(
      KnowledgeGraphNamedObjectValue kg_named_obj_val)
      if (kg_named_obj_val is KnowledgeGraphEntityValue kg_entity)
        var label = kg_entity.GetLabel();
        //TODO - use label
      else if (kg_named_obj_val is KnowledgeGraphRelationshipValue kg_rel)
        var has_entity_ids = kg_rel.GetHasRelatedEntityIDs();
        if (kg_rel.GetHasRelatedEntityIDs())
          var origin_id = kg_rel.GetOriginID();
          var dest_id = kg_rel.GetDestinationID();
          //TODO - use ids
      var id = kg_named_obj_val.GetID();
      var oid = kg_named_obj_val.GetObjectID();
      //Note: Typename corresponds to the name of the feature class or table
      //in the relational gdb model -and- to the name of the KnowledgeGraphNamedObjectType
      //in the knowledge graph data model
      var type_name = kg_named_obj_val.GetTypeName();
      //TODO use id, object id, etc.
    //Object values include entities, relationships, and anonymous objects
    void ProcessGraphObjectValue(KnowledgeGraphObjectValue kg_obj_val)
      switch (kg_obj_val)
        case KnowledgeGraphEntityValue kg_entity:
          ProcessGraphNamedObjectValue(kg_entity);
          break;
        case KnowledgeGraphRelationshipValue kg_rel:
          ProcessGraphNamedObjectValue(kg_rel);
          break;
        default:
          //Anonymous objects
          break;
      //graph object values have a set of properties (equivalent
      //to a collection of key/value pairs)
      var keys = kg_obj_val.GetKeys();
      foreach (var key in keys)
        ProcessKnowledgeGraphRowValue(kg_obj_val[key]);//Recurse
    //Process a KnowledgeGraphValue from a query or search
    void ProcessGraphValue(KnowledgeGraphValue kg_val)
      switch (kg_val)
        case KnowledgeGraphPrimitiveValue kg_prim:
          //KnowledgeGraphPrimitiveValue not currently used in
          //query and search
          ProcessKnowledgeGraphRowValue(kg_prim.GetValue());//Recurse
          return;
        case KnowledgeGraphArrayValue kg_array:
          var count = kg_array.GetSize();
          //Recursively process each value in the array
          for (ulong i = 0; i < count; i++)
            ProcessKnowledgeGraphRowValue(kg_array[i]);//Recurse
          return;
        case KnowledgeGraphPathValue kg_path:
          //Entities
          var entity_count = kg_path.GetEntityCount();
          //Recursively process each entity value in the path
          for (ulong i = 0; i < entity_count; i++)
            ProcessGraphObjectValue(kg_path.GetEntity(i));//Recurse
          //Recursively process each relationship value in the path
          var relate_count = kg_path.GetRelationshipCount();
          for (ulong i = 0; i < relate_count; i++)
            ProcessGraphObjectValue(kg_path.GetRelationship(i));//Recurse
          return;
        case KnowledgeGraphObjectValue kg_object:
          ProcessGraphObjectValue(kg_object);//Recurse
          return;
        default:
          var type_string = kg_val.GetType().ToString();
          System.Diagnostics.Debug.WriteLine(
            $"Unknown: '{type_string}'");
          return;
    //Process each value from the KnowledgeGraphRow array
    void ProcessKnowledgeGraphRowValue(object value)
      switch (value)
        //Graph value?
        case KnowledgeGraphValue kg_val:
          var kg_type = kg_val.KnowledgeGraphValueType.ToString();
            $"KnowledgeGraphValue: '{kg_type}'");
          ProcessGraphValue(kg_val);//Recurse
          return;
        //Primitive types...add additional logic as needed
        case System.DBNull dbn:
          System.Diagnostics.Debug.WriteLine("DBNull.Value");
          return;
        case string str:
          System.Diagnostics.Debug.WriteLine($"'{str}' (string)");
          return;
        case long l_val:
          System.Diagnostics.Debug.WriteLine($"{l_val} (long)");
          return;
        case int i_val:
          System.Diagnostics.Debug.WriteLine($"{i_val} (int)");
          return;
        case short s_val:
          System.Diagnostics.Debug.WriteLine($"{s_val} (short)");
          return;
        case double d_val:
          System.Diagnostics.Debug.WriteLine($"{d_val} (double)");
          return;
        case float f_val:
          System.Diagnostics.Debug.WriteLine($"{f_val} (float)");
          return;
        case DateTime dt_val:
          System.Diagnostics.Debug.WriteLine($"{dt_val} (DateTime)");
          return;
        case DateOnly dt_only_val:
          System.Diagnostics.Debug.WriteLine($"{dt_only_val} (DateOnly)");
          return;
        case TimeOnly tm_only_val:
          System.Diagnostics.Debug.WriteLine($"{tm_only_val} (TimeOnly)");
          return;
        case DateTimeOffset dt_tm_offset_val:
            $"{dt_tm_offset_val} (DateTimeOffset)");
          return;
        case System.Guid guid_val:
          var guid_string = guid_val.ToString("B");
          System.Diagnostics.Debug.WriteLine($"'{guid_string}' (Guid)");
          return;
        case ArcGIS.Core.Geometry.Geometry geom_val:
          var geom_type = geom_val.GeometryType.ToString();
          var is_empty = geom_val.IsEmpty;
          var wkid = geom_val.SpatialReference?.Wkid ?? 0;
            $"geometry: {geom_type}, empty: {is_empty}, sr_wkid {wkid} (shape)");
          return;
        default:
          //Blob? Others?
          var type_str = value.GetType().ToString();
          System.Diagnostics.Debug.WriteLine($"Primitive: {type_str}");
          return;
    // ...submit query or search
    //using (var kgRowCursor = kg.SubmitQuery(kg_qf)) {
    //using (var kgRowCursor = kg.SubmitSearch(kg_sf)) {
    //  ...wait for rows ...
    //  while (await kgRowCursor.WaitForRowsAsync()) {
    //   ...rows have been retrieved
    //   while (kgRowCursor.MoveNext()) {
    //     ...get the current KnowledgeGraphRow
    //     using (var graph_row = kgRowCursor.Current) {
    //        var val_count = (int)graph_row.GetCount();
    //        for (int i = 0; i<val_count; i++)
    //           ProcessKnowledgeGraphRowValue(graph_row[i]);
    Requirements
    ArcGIS Pro version: 3.2 or higher.
