ArcGIS.Desktop.Editing Namespace / AnnotationProperties Class / Color Property
Example
    Color Property (AnnotationProperties)
    Gets and sets the color.
    Syntax
    public CIMColor Color {get; set;}
    Public Property Color As CIMColor
    Example
    Programmatically Create an Annotation Feature
    await QueuedTask.Run(() =>
        // annotationLayer is ~your~ Annotation layer...
        // annotationPoint is ~your~ Annotation's location geometry ...
        var op = new EditOperation();
        // Use the inspector
        var insp = new Inspector();
        insp.LoadSchema(annotationLayer);
        // get the annotation properties from the inspector
        AnnotationProperties annoProperties = insp.GetAnnotationProperties();
        // change the annotation text
        annoProperties.TextString = DateTime.Now.ToLongTimeString();
        // change font color to green
        annoProperties.Color = ColorFactory.Instance.GreenRGB;
        // change the horizontal alignment
        annoProperties.HorizontalAlignment = HorizontalAlignment.Center;
        annoProperties.Shape = annotationPoint;
        // set the annotation properties back on the inspector
        insp.SetAnnotationProperties(annoProperties);
        // create the annotation
        op.Create(annotationLayer, insp);
        if (!op.IsEmpty)
          var result = op.Execute(); //Execute and ExecuteAsync will return true if the operation was successful and false if not
    Requirements
