ArcGIS.Desktop.Editing Namespace / AnnotationProperties Class / FontSize Property
Example
    FontSize Property (AnnotationProperties)
    Gets and sets the font size.
    Syntax
    public Nullable<double> FontSize {get; set;}
    Public Property FontSize As Nullable(Of Double)
    Example
    Create Annotation Template
    // Creates a new annotation template for the specified annotation layer.
    await QueuedTask.Run(() =>
        Inspector insp = null;
        // get the anno feature class
        var fc = annotationLayer.GetFeatureClass() as ArcGIS.Core.Data.Mapping.AnnotationFeatureClass;
        // get the feature class CIM definition which contains the labels, symbols
        var cimDefinition = fc.GetDefinition() as ArcGIS.Core.Data.Mapping.AnnotationFeatureClassDefinition;
        var labels = cimDefinition.GetLabelClassCollection();
        var symbols = cimDefinition.GetSymbolCollection();
        // make sure there are labels, symbols
        if (labels.Count == 0 || symbols.Count == 0)
          return;
        // find the label class required
        //   typically you would use a subtype name or some other characteristic
        // in this case lets just use the first one
        var label = labels[0];
        // each label has a textSymbol
        // the symbolName *should* be the symbolID to be used
        var symbolName = label.TextSymbol.SymbolName;
        int symbolID = -1;
        if (!int.TryParse(symbolName, out symbolID))
          // int.TryParse fails - attempt to find the symbolName in the symbol collection
          foreach (var symbol in symbols)
            if (symbol.Name == symbolName)
              symbolID = symbol.ID;
              break;
        // no symbol?
        if (symbolID == -1)
          return;
        // load the schema
        insp = new Inspector();
        insp.LoadSchema(annotationLayer);
        // ok to assign these fields using the inspector[fieldName] methodology
        //   these fields are guaranteed to exist in the annotation schema
        insp["AnnotationClassID"] = label.ID;
        insp["SymbolID"] = symbolID;
        // set up some additional annotation properties
        AnnotationProperties annoProperties = insp.GetAnnotationProperties();
        annoProperties.FontSize = 36;
        annoProperties.TextString = "My Annotation feature";
        annoProperties.VerticalAlignment = VerticalAlignment.Top;
        annoProperties.HorizontalAlignment = HorizontalAlignment.Justify;
        insp.SetAnnotationProperties(annoProperties);
        var tags = new[] { "Annotation", "tag1", "tag2" };
        // use daml-id rather than guid
        string defaultTool = "esri_editing_SketchStraightAnnoTool";
        // tool filter is the tools to filter OUT
        var toolFilter = new[] { "esri_editing_SketchCurvedAnnoTool" };
        // create a new template
        var newTemplate = annotationLayer.CreateTemplate("new annotation template", "description", insp, defaultTool, tags, toolFilter);
    Requirements
