public Nullable<VerticalAlignment> VerticalAlignment {get; set;}
Public Property VerticalAlignment As Nullable(Of VerticalAlignment)
// Creates a new annotation template for the specified annotation layer. await QueuedTask.Run(() => { Inspector insp = null; // get the anno feature class var fc = annotationLayer.GetFeatureClass() as ArcGIS.Core.Data.Mapping.AnnotationFeatureClass; // get the feature class CIM definition which contains the labels, symbols var cimDefinition = fc.GetDefinition() as ArcGIS.Core.Data.Mapping.AnnotationFeatureClassDefinition; var labels = cimDefinition.GetLabelClassCollection(); var symbols = cimDefinition.GetSymbolCollection(); // make sure there are labels, symbols if (labels.Count == 0 || symbols.Count == 0) { return; } // find the label class required // typically you would use a subtype name or some other characteristic // in this case lets just use the first one var label = labels[0]; // each label has a textSymbol // the symbolName *should* be the symbolID to be used var symbolName = label.TextSymbol.SymbolName; int symbolID = -1; if (!int.TryParse(symbolName, out symbolID)) { // int.TryParse fails - attempt to find the symbolName in the symbol collection foreach (var symbol in symbols) { if (symbol.Name == symbolName) { symbolID = symbol.ID; break; } } } // no symbol? if (symbolID == -1) { return; } // load the schema insp = new Inspector(); insp.LoadSchema(annotationLayer); // ok to assign these fields using the inspector[fieldName] methodology // these fields are guaranteed to exist in the annotation schema insp["AnnotationClassID"] = label.ID; insp["SymbolID"] = symbolID; // set up some additional annotation properties AnnotationProperties annoProperties = insp.GetAnnotationProperties(); annoProperties.FontSize = 36; annoProperties.TextString = "My Annotation feature"; annoProperties.VerticalAlignment = VerticalAlignment.Top; annoProperties.HorizontalAlignment = HorizontalAlignment.Justify; insp.SetAnnotationProperties(annoProperties); var tags = new[] { "Annotation", "tag1", "tag2" }; // use daml-id rather than guid string defaultTool = "esri_editing_SketchStraightAnnoTool"; // tool filter is the tools to filter OUT var toolFilter = new[] { "esri_editing_SketchCurvedAnnoTool" }; // create a new template var newTemplate = annotationLayer.CreateTemplate("new annotation template", "description", insp, defaultTool, tags, toolFilter); });
