ArcGIS.Core.Data.Knowledge Namespace / KnowledgeGraphUniformIdentifier Class / GetIdentifierName Method
Example
    Get the name of the property serving as the unique identifier for entities and relationships in the knowledge graph. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public string GetIdentifierName()
    Public Function GetIdentifierName() As String
    Return Value
    Exceptions
    ExceptionDescription
    Example
    Get Data Model Identifier Info
      await QueuedTask.Run(() =>
        //Create a connection properties
        var kg_props =
            new KnowledgeGraphConnectionProperties(new Uri(url));
        using (var kg = new KnowledgeGraph(kg_props))
          //Get the KnowledgeGraph Data Model
          using (var kg_dm = kg.GetDataModel())
            var kg_id_info = kg_dm.GetIdentifierInfo();
            var kg_id_gen = kg_id_info.GetIdentifierGeneration();
            if (kg_id_info is KnowledgeGraphNativeIdentifier kg_ni)
              System.Diagnostics.Debug.WriteLine(
                $"IdentifierInfo: KnowledgeGraphNativeIdentifier");
            else if (kg_id_info is KnowledgeGraphUniformIdentifier kg_ui)
                $"IdentifierInfo: KnowledgeGraphUniformIdentifier");
                $"IdentifierName: '{kg_ui.GetIdentifierName()}'");
              $"Identifier MethodHint: {kg_id_gen.GetMethodHint()}");
    Requirements
    ArcGIS Pro version: 3.2 or higher.
