ArcGIS.Desktop.Mapping Namespace / KnowledgeGraphLayerCreationParams Class / KnowledgeGraphLayerCreationParams Constructor / KnowledgeGraphLayerCreationParams Constructor(KnowledgeGraph)
A ArcGIS.Core.Data.Knowledge.KnowledgeGraph object.
Example
    Creates a parameter object with a ArcGIS.Core.Data.Knowledge.KnowledgeGraph.
    Syntax
    Public Function New( _
       ByVal knowledgeGraph As KnowledgeGraph _
    public KnowledgeGraphLayerCreationParams(
       KnowledgeGraph knowledgeGraph
    Parameters
    knowledgeGraph
    Example
    Create a KG Layer containing all Entity and Relate types
      await QueuedTask.Run(() =>
        //With a connection to a KG established or source uri available...
        //Create a KnowledgeGraphLayerCreationParams
        var kg_params = new KnowledgeGraphLayerCreationParams(kg)
          Name = "KG_With_All_Types",
          IsVisible = false
        //Or
        var kg_params2 = new KnowledgeGraphLayerCreationParams(new Uri(url))
          IsVisible = false
        //Call layer factory with map or group layer container.
        //A KG layer containing a feature layer and/or standalone table per
        //entity and relate type (except provenance) is created
        var kg_layer = LayerFactory.Instance.CreateLayer<KnowledgeGraphLayer>(
            kg_params, map);
    Requirements
    ArcGIS Pro version: 3.2 or higher.
