ArcGIS.Desktop.Layouts Namespace / Element Class / ConvertToGraphics Method
    ConvertToGraphics Method (Element)
    Convert the element to graphics. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function ConvertToGraphics() As IList(Of IElement)
    public IList<IElement> ConvertToGraphics()
    Return Value
    The list result will contain just one, selected GroupElement that contains all the individual element within it.
    Exceptions
    ExceptionDescription
    This method must be called within the lambda passed to QueuedTask.Run.
    Remarks
    If the element cannot be converted then null is returned. Refer to CanConvertToGraphics
    . The element is removed from the layout and the new graphic elements are added in its place.
    Requirements
