ArcGIS.Desktop.Mapping Namespace / PopupContent Class / IDString Property
Example
    IDString Property
    Gets or sets a "generic string feature id" associated with the pop-up. Can be empty if the pop-up is not associated with a feature using a string.
    Syntax
    public string IDString {get; set;}
    Public Property IDString As String
    Example
    Show A pop-up With Custom Commands
      //Create custom popup content from existing map member and object id
      List<PopupContent> popups = [new PopupContent(mapMember, objectID)];
      //Create a new custom command to add to the popup window
      List<PopupCommand> commands =
        new PopupCommand(
              p => MessageBox.Show(string.Format("Map Member: {0}, ID: {1}", p.MapMember, p.IDString)),
              p => { return p != null; },
              "My custom command",
              System.Windows.Application.Current.Resources["GenericCheckMark16"] as ImageSource),
      mapView.ShowCustomPopup(popups, commands, true);
    Requirements
