ArcGIS.Core.Data Namespace / AttributeRuleManager Class / UpdateErrors Method
A IEnumerable of one or more AttributeRuleError objects.
    UpdateErrors Method
    Updates the validation error system tables specified by validationErrors. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Parameters
    validationErrors
    Exceptions
    ExceptionDescription
    A validation service is not supported or enabled for this geodatabase.
    validationErrors is null or empty.
    A geodatabase-related exception has occurred.
    Remarks
    • If IsEvaluationSupported returns false, calling this method will result in an exception.
    • This routine generates its own editing transaction and therefore cannot be wrapped inside a separate transaction.
    • When writing an ArcGIS Pro add-in, the extension method CoreDataExtensions.UpdateErrorsInEditOperation should be used instead. This extension method will create an edit operation on the Pro undo/redo stack and redraw any affected layers.
    Requirements
