ArcGIS.Core.Data Namespace / Table Class / GetArchiveTable Method
    GetArchiveTable Method (Table)
    Gets the archive table associated with this table or feature class if it is archived-enabled. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetArchiveTable() As Table
    public Table GetArchiveTable()
    Return Value
    The archive table associated with this table or feature class if it is archived-enabled.
    Exceptions
    ExceptionDescription
    This table is not archive-enabled or does not support archiving.
    A geodatabase-related exception has occurred.
    Remarks
    If IsArchiveEnabled returns false, calling this method will result in an exception.
    Requirements
