ArcGIS.Core.Data.PluginDatastore Namespace / PluginDatastore Class / GetDefinition Method
The name of the table to open.
    GetDefinition Method (PluginDatastore)
    Gets the ArcGIS.Core.Data.TableDefinition or ArcGIS.Core.Data.FeatureClassDefinition (if the table returned by OpenTable can be cast to ArcGIS.Core.Data.FeatureClass) associated with name. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public TableDefinition GetDefinition(
       string name
    Public Function GetDefinition( _
       ByVal name As String _
    ) As TableDefinition
    Parameters
    name
    Return Value
    Exceptions
    ExceptionDescription
    No valid plug-in data store has been opened prior to calling this operation.
    name is null or an empty string.
    A geodatabase-related exception has occurred.
    Requirements
