ArcGIS.Core.Data.PluginDatastore Namespace / PluginDatastore Class
Properties Methods
    PluginDatastore Class Members
    The following tables list the members exposed by PluginDatastore.
    Public Constructors
     NameDescription
    Public Constructor Opens a read-only plug-in data store that makes a third-party data format accessible to ArcGIS Pro.
    Top
    Public Properties
     NameDescription
    Public Property Gets the opaque handle to the underlying native object. (Inherited from ArcGIS.Core.CoreObjectsBase)
    Top
    Public Methods
     NameDescription
    Public Method Gets a value indicating whether this datastore supports datastore properties. (Inherited from ArcGIS.Core.Data.Datastore)
    Public Method (Inherited from ArcGIS.Core.CoreObjectsBase)
    Public Method Gets the connection string associated with the currently opened data store (e.g., an enterprise geodatabase). This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.Datastore)
    Public MethodOverridden. Gets the ArcGIS.Core.Data.Connector associated with the currently opened plug-in data store. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Gets the datastore properties of the datastore. (Inherited from ArcGIS.Core.Data.Datastore)
    Public MethodGets the ArcGIS.Core.Data.TableDefinition or ArcGIS.Core.Data.FeatureClassDefinition (if the table returned by OpenTable can be cast to ArcGIS.Core.Data.FeatureClass) associated with name. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Gets the path to the currently opened data store (e.g., an enterprise geodatabase .sde connection file). This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.Datastore)
    Public MethodGets the gateway to access information about the SQL syntax and other functionality supported by this ArcGIS.Core.Data.Datastore. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.Datastore)
    Public Method Gets the name of all the tables that exist in the currently opened plug-in data store. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Determines whether the currently opened data store (e.g., an enterprise geodatabase) has any pending edits which have not been saved. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.Datastore)
    Public MethodGets the ArcGIS.Core.Data.Table or ArcGIS.Core.Data.FeatureClass (if it is spatially enabled) associated with name. This method must be called on the MCT. Use QueuedTask.Run.
    Top
