ArcGIS.Core.Geometry Namespace / GeometryEngine Class / GetNormalsAtM Method
The multipart containing the M-values. If the multipart is a polygon, then the boundary is used.
The M-value at which to construct the normal line.
The length of the normal line. A positive value means the normal lines are on the right side of the multipart. A negative value means the normal lines are on the left side of the multipart.
Example
    GetNormalsAtM Method (GeometryEngine)
    Gets the line segments corresponding to the normal at the locations along the geometry where the specified M occurs.
    Syntax
    Public Function GetNormalsAtM( _
       ByVal multipart As Multipart, _
       ByVal mValue As Double, _
       ByVal length As Double _
    ) As Polyline
    public Polyline GetNormalsAtM(
       Multipart multipart,
       double mValue,
       double length
    Parameters
    multipart
    mValue
    length
    Return Value
    A polyline. Each part of the polyline is a normal line. If the input multipart is empty, then an empty polyline is returned.
    Exceptions
    ExceptionDescription
    Multipart is null or empty.
    This geometry is not M-Aware.
    Spatial reference of multipartis an image coordinate system.
    Example
    Get line segments corresponding to the normal at the locations where the specified M values occur along the geometry - GetNormalsAtM
      IList<MapPoint> inPoints =
        MapPointBuilderEx.CreateMapPoint(-3000, -2000, 0, 100),
    MapPointBuilderEx.CreateMapPoint(-3000, 0, 0, 200),
    MapPointBuilderEx.CreateMapPoint(-1000, 0, 0, 300),
    MapPointBuilderEx.CreateMapPoint(-1000, 2000, 0, 100),
    MapPointBuilderEx.CreateMapPoint(3000, 2000, 0, 200),
    MapPointBuilderEx.CreateMapPoint(3000, 0, 0, 300),
    MapPointBuilderEx.CreateMapPoint(1000, 0, 0, 100),
    MapPointBuilderEx.CreateMapPoint(1000, -2000, 0, 200),
    MapPointBuilderEx.CreateMapPoint(-3000, -2000, 0, 300)
      polygon = PolygonBuilderEx.CreatePolygon(inPoints);
      // polygon.HasM = true
      polyline = GeometryEngine.Instance.GetNormalsAtM(polygon, 150, 100);
      // polyline.PartCount = 5
      // polyline.PointCount = 10
      // polyline.HasM = false
      ReadOnlyPartCollection parts = polyline.Parts;
      ReadOnlySegmentCollection segments = parts[0];
      LineSegment line = segments[0] as LineSegment;
      // line.StartCoordinate = (-3000, -1000)
      // line.EndCoordinate = (-2900, -1000)
      segments = parts[1];
      // line.StartCoordinate = (-1000, 1500)
      // line.EndCoordinate = (-900, 1500)
      segments = parts[2];
      // line.StartCoordinate = (1000, 2000)
      // line.EndCoordinate = (1000, 1900)
      segments = parts[3];
      // line.StartCoordinate = (1500, 0)
      // line.EndCoordinate = (1500, 100)
      segments = parts[4];
      // line.StartCoordinate = (1000, -1000)
      // line.EndCoordinate = (900, -1000)
    Requirements
