ArcGIS.Core.Geometry Namespace / ReadOnlyPointCollection Class / Copy3DCoordinatesToList Method / Copy3DCoordinatesToList(Int32,Int32,ICollection<Coordinate3D>) Method
The index of the first point to copy.
The number of points to copy.
The list of 3D coordinates into which the points are copied.
Example
    Copies the MapPoints in this list to the given list of 3D coordinates.
    Syntax
    public void Copy3DCoordinatesToList(
       int startIndex,
       int pointCount,
       ref ICollection<Coordinate3D> coordinates
    Public Overloads Sub Copy3DCoordinatesToList( _
       ByVal startIndex As Integer, _
       ByVal pointCount As Integer, _
       ByRef coordinates As ICollection(Of Coordinate3D) _
    Parameters
    startIndex
    pointCount
    coordinates
    Exceptions
    ExceptionDescription
    coordinates is null.
    pointCount is less than zero.
    startIndex + pointCount is greater than the actual number of points in this list.
    Remarks
    Use this method to get a list of lightweight structures from the points of a geometry on which low-level calculations may be performed. Performance may be improved by reusing the same list for each geometry. For optimal performance, the coordinates should have a capacity greater than or equal to the number of points that are to be copied.
    Example
    Get the points of a Polyline
      // get the points as a readonly Collection
      //Refer to the initialization region for polyline creation
      ReadOnlyPointCollection pts = polyline.Points;
      int numPts = polyline.PointCount;
      // OR   get an enumeration of the points
      IEnumerator<MapPoint> enumPts = polyline.Points.GetEnumerator();
      // OR   get the point coordinates as a readonly list of Coordinate2D
      IReadOnlyList<Coordinate2D> coordinates = polyline.Copy2DCoordinatesToList();
      // OR   get the point coordinates as a readonly list of Coordinate3D
      IReadOnlyList<Coordinate3D> coordinates3D = polyline.Copy3DCoordinatesToList();
      // OR   get a subset of the collection as Coordinate2D using preallocated memory
      IList<Coordinate2D> coordinate2Ds = new List<Coordinate2D>(10);   // allocate some space
      ICollection<Coordinate2D> subsetCoordinates2D = coordinate2Ds;    // assign
      pts.Copy2DCoordinatesToList(1, 2, ref subsetCoordinates2D);       // copy 2 elements from index 1 into the allocated list
        // coordinate2Ds.Count = 2
        // do something with the coordinate2Ds
      // without allocating more space, obtain a different set of coordinates
      pts.Copy2DCoordinatesToList(5, 9, ref subsetCoordinates2D);       // copy 9 elements from index 5 into the allocated list
        // coordinate2Ds.Count = 9
      // OR   get a subset of the collection as Coordinate3D using preallocated memory
      IList<Coordinate3D> coordinate3Ds = new List<Coordinate3D>(15);   // allocate some space
      ICollection<Coordinate3D> subsetCoordinates3D = coordinate3Ds;    // assign
      pts.Copy3DCoordinatesToList(3, 5, ref subsetCoordinates3D);       // copy 5 elements from index 3 into the allocated list
        // coordinate3Ds.Count = 5
      // OR   get a subset of the collection as MapPoint using preallocated memory
      IList<MapPoint> mapPoints = new List<MapPoint>(7);   // allocate some space
      ICollection<MapPoint> subsetMapPoint = mapPoints;    // assign
      pts.CopyPointsToList(1, 4, ref subsetMapPoint);      // copy 4 elements from index 1 into the allocated list
                                                           // mapPoints.Count = 4
    Requirements
