ArcGIS.Core.Data Namespace / DatastoreProperties Class / SupportsQueryPagination Property
Example
    Gets whether the datastore supports query pagination.
    Syntax
    Public ReadOnly Property SupportsQueryPagination As Boolean
    public bool SupportsQueryPagination {get;}
    Example
    Get datastore or workspace properties
      // Must be called within QueuedTask.Run
      void GetDatastoreProperties(Datastore geodatabase)
        // Check if a data store supports datastore properties
        bool areDatastorePropertiesSupported = geodatabase.AreDatastorePropertiesSupported();
        if (areDatastorePropertiesSupported)
          DatastoreProperties datastoreProperties = geodatabase.GetDatastoreProperties();
          // Supports 64-bit integer field
          bool supportsBigInteger = datastoreProperties.SupportsBigInteger;
          // Supports pagination
          bool supportsQueryPagination = datastoreProperties.SupportsQueryPagination;
          // Supports datastore edit
          bool canEdit = datastoreProperties.CanEdit;
          // Supports 64-bit Object ID
          bool supportsBigObjectId = datastoreProperties.SupportsBigObjectID;
          // Supports DateOnly field
          bool supportsDateOnly = datastoreProperties.SupportsDateOnly;
          // Supports TimeOnly field
          bool supportsTimeOnly = datastoreProperties.SupportsTimeOnly;
          // Supports TimestampOffset field
          bool supportsTimestampOffset = datastoreProperties.SupportsTimestampOffset;
    Requirements
    ArcGIS Pro version: 3.3 or higher.
