ArcGIS.Core.Data Namespace / QueryFilter Class / RowCount Property
Example
    RowCount Property (QueryFilter)
    Gets or sets the limit to the number of rows returned by the query.
    Syntax
    public int RowCount {get; set;}
    Public Property RowCount As Integer
    Remarks
    Some datastores support pagination only through an SQL postfix clause; in these cases, the PostfixClause property should be used in conjunction with RowCount.
    In FSDB, if ObjectIDs property is set, the RowCount value will be ignored for the better performance.
    Example
    Fulltext search query
      await QueuedTask.Run(() =>
        using (Geodatabase geodatabase = new Geodatabase(new DatabaseConnectionFile(new Uri("path\\to\\sde\\file\\sdefile.sde"))))
        using (Table table = geodatabase.OpenDataset<Table>("WaterPipeInfo"))
        using (TableDefinition tableDefinition = table.GetDefinition())
          bool supportsFullText = geodatabase.GetDatastoreProperties().SupportsFullTextIndex;
          if (!supportsFullText)
            return;
          IReadOnlyList<Index> indexes = tableDefinition.GetIndexes();
          IReadOnlyList<Field> fieldsToSearch = indexes.First().GetFields();
          FullTextSearchTermExpression searchRepairStatus = new FullTextSearchTermExpression()
            SearchFields = fieldsToSearch[0].Name,
            SearchTerm = "Repaired",
            SearchType = FullTextSearchType.Simple
          FullTextSearchTermExpression searchPipeMaterial = new FullTextSearchTermExpression()
            SearchFields = fieldsToSearch[1].Name,
            SearchTerm = "Copper",
          FullTextOrExpression repairedOrCopperEx = new FullTextOrExpression(searchRepairStatus, searchPipeMaterial);
          QueryFilter queryfilter = new QueryFilter
            FullTextExpression = repairedOrCopperEx,
            Offset = 1,
            RowCount = 20,
            PostfixClause = "Order By Size"
          using (RowCursor rowCursor = table.Search(queryfilter, false))
            // Use row cursor ...
    Pagination in QueryFilter
      Task QueryFilterWithPaginationAsync(Table table, List<long> objectIDs) => QueuedTask.Run(() =>
        int rowsPerBatch = 100;
        int offset = 0;
        // Query filter
        // Some datastores support pagination only through an SQL postfix clause
        QueryFilter queryFilter = new QueryFilter()
          ObjectIDs = objectIDs,
          PostfixClause = "ORDER BY OBJECTID"
        // Fetch rows in a batch from a table
        for (int index = offset; index <= objectIDs.Count; index += rowsPerBatch)
          // Set number of rows to return from a table
          queryFilter.RowCount = rowsPerBatch;
          // Set positional offset to skip number of rows from a table
          queryFilter.Offset = index;
          using (RowCursor cursor = table.Search(queryFilter))
            while (cursor.MoveNext())
              using (Row row = cursor.Current)
                Console.WriteLine(row.GetObjectID());
    Requirements
    ArcGIS Pro version: 3.3 or higher.
