ArcGIS.Core.Data.Knowledge Namespace / KnowledgeGraph Class / TransformToIDs Method
Name of the Knowledge Graph type the objectIDs are associated with.
The set of objectIDs to translate.
Example
    Translates a set of objectIDs for a Knowledge Graph type into IDs. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function TransformToIDs( _
       ByVal typeName As String, _
       ByVal oids As IEnumerable(Of Long) _
    ) As IReadOnlyList(Of Object)
    Parameters
    typeName
    oids
    Return Value
    The set of IDs
    Exceptions
    ExceptionDescription
    typeName cannot be empty or null.
    Example
    Transform a set of objectIDs to IDs for an entity
      await QueuedTask.Run(() =>
        var kg_props =
                new KnowledgeGraphConnectionProperties(new Uri(url));
        //Connect to the KnowledgeGraph datastore
        //KnowledgeGraph datastores contain tables and feature classes
        using (var kg = new KnowledgeGraph(kg_props))
          string entityName = "Name-of-the-entity";
          var oidList = new List<long>() { 260294, 678, 3523, 3, 669, 93754 };
          var idList = kg.TransformToIDs(entityName, oidList);
    Requirements
    ArcGIS Pro version: 3.3 or higher.
