public KnowledgeGraphObjectValue BindParameters {get;}
Public ReadOnly Property BindParameters As KnowledgeGraphObjectValue
| Exception | Description |
| ArcGIS.Core.CalledOnWrongThreadException | This method or property must be called within the lambda passed to QueuedTask.Run. |
await QueuedTask.Run(async () =>
//assume we have, in this case, a list of ids (perhaps retrieved
//via a selection, hardcoded (like here), etc.
var oids = new List<long>() { 3,4,7,8,9,11,12,14,15,19,21,25,29,
31,32,36,37,51,53,54,55,56,59,63,75,78,80,84,86,88,96,97,98,101,
103,106};
//In the query, we refer to the "bind parameter" with the
//"$" and a variable name - '$object_ids' in this example
var qry = @"MATCH (p:PhoneNumber) " +
@" WHERE p.objectid IN $object_ids " +
@"RETURN p";
//we provide the values to be substituted for the variable via the
//KnowledgeGraphQueryFilter BindParameter property...
var kg_qry_filter = new KnowledgeGraphQueryFilter()
QueryText = qry
//the bind parameter added to the query filter must refer to
//the variable name used in the query string (without the "$")
//Note:
//Collections must be converted to a KnowledgeGraphArrayValue before
//being assigned to a BindParameter
var kg_oid_array = new KnowledgeGraphArrayValue();
kg_oid_array.AddRange(oids);
oids.Clear();
kg_qry_filter.BindParameters["object_ids"] = kg_oid_array;
//submit the query
using (var kgRowCursor = kg.SubmitQuery(kg_qry_filter))
//wait for rows to be returned asynchronously from the server
while (await kgRowCursor.WaitForRowsAsync())
//get the rows using "standard" move next
while (kgRowCursor.MoveNext())
//current row is accessible via ".Current" prop of the cursor
using (var graphRow = kgRowCursor.Current)
var cell_phone = graphRow[0] as KnowledgeGraphEntityValue;
var oid = cell_phone.GetObjectID();
var name = (string)cell_phone["FULL_NAME"];
var ph_number = (string)cell_phone["PHONE_NUMBER"];
System.Diagnostics.Debug.WriteLine(
$"[{oid}] {name}, {ph_number}");
var mapView = MapView.Active;
if (mapView == null)
return;
103,106};
//"$" and a variable name - '$object_ids' and '$sel_geom'
//in this example
@"WHERE p.objectid IN $object_ids AND " +
@"esri.graph.ST_Intersects($sel_geom, p.shape) " +
@"RETURN p";
//create a KG query filter
QueryText = qry
//Note:
//Create a polygon based on current map extent
var extent = mapView.Extent;
var poly = PolygonBuilder.CreatePolygon(extent.Expand(0.25, 0.25, true));
kg_qry_filter.BindParameters["sel_geom"] = poly;
oids.Clear();
//submit the query
// cref: ArcGIS.Core.Data.Knowledge.KnowledgeGraphNamedObjectValue.GetObjectID()
#region Process Row
