ArcGIS.Desktop.Layouts Namespace / MapFrame Class / GetMapView Method
Example
    GetMapView Method
    Gets the map Frame's viewer on the specified layout pane. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public MapView GetMapView(
       LayoutView layoutView
    Public Function GetMapView( _
       ByVal layoutView As LayoutView _
    ) As MapView
    Parameters
    layoutView
    Return Value
    Returns a MapView.
    Exceptions
    ExceptionDescription
    Remarks
    Note: the layout pane containing the viewer must be open. To navigate the map frame without an open layout pane, use the map frame's camera instead.
    Example
    Export the map view associated with a map frame to BMP
      //Export the map view associated with a map frame to BMP.
      string filePath = @"Path and file name for the output export file";
      //Create BMP format with appropriate settings
      //EMF, EPS, GIF, JPEG, PDF, PNG, SVG, TGA, and TFF formats are also available for export
      BMPFormat BMP = new BMPFormat()
        Resolution = 300,
        Height = 500,
        Width = 800,
        HasWorldFile = true,
        OutputFileName = filePath
      //Export on the worker thread
      await QueuedTask.Run(() =>
        MapView mv_bmp = mapFrame.GetMapView(layoutView);
        if (mv_bmp != null)
          //Check to see if the path is valid and export
          if (BMP.ValidateOutputFilePath())
            mv_bmp.Export(BMP);  //Export to BMP
    SetAutoCameraFixedCenter
      var activeLayoutView = LayoutView.Active;
        var autoCamera = mapFrame.GetAutoCamera();
        autoCamera.Source = AutoCameraSource.Fixed;
        autoCamera.AutoCameraType = AutoCameraType.Center;
        var camera = mapFrame.GetMapView(activeLayoutView).Camera;
        var center = mapFrame.GetViewCenter();
      //var extent = EnvelopeBuilderEx.CreateEnvelope(
      //	400748.62, 800296.4, 1310669.05, 1424520.74, mf.Map.SpatialReference);
      //autoCamera.Extent = extent;
        var camera2 = new CIMViewCamera()
          Heading = 0,
          Pitch = -90,
          Roll = 0,
          Scale = 21169571,
          X = 855708,
          Y = 1112409,
          Z = double.NaN
        autoCamera.Camera = camera2;
        var states = mapFrame.Map.GetLayersAsFlattenedList().First(l => l.Name == "State_Polygons");
        autoCamera.IntersectLayerPath = states.URI;
        if (mapFrame.ValidateAutoCamera(autoCamera) &&
          !mapFrame.IsMapSeriesMapFrame())
          mapFrame.SetAutoCamera(autoCamera);
    SetAutoCameraFixedCenterAndScale
        autoCamera.AutoCameraType = AutoCameraType.CenterAndScale;
          Heading = 0,
          Pitch = -90,
          Roll = 0,
          Scale = 21169571,
          X = 1310669.0 + ((400748.5 - 1310669.0) / 2.0),
          Y = 800296.4 + ((1424520.74 - 800296.4) / 2.0),
          Z = double.NaN
        //autoCamera.IntersectLayerPath = states.URI;
    SetAutoCameraFixedScale
        autoCamera.AutoCameraType = AutoCameraType.Scale;
          Heading = 0,
          Pitch = -90,
          Roll = 0,
          Scale = 20000571,
          Z = double.NaN
    Requirements
