public ExportFileOptions ExportFileOptions {get; set;}
Public Property ExportFileOptions As ExportFileOptions
For PDF export, there are 3 options: a single, multiple page PDF, individual pages using the map name as a suffix, or individual pages using page numbers as a suffix.
For all other export formats, there are only two valid options: individual pages using the map name as a suffix, or individual pages using page numbers as a suffix.
//Export a map series with multiple pages to a single PDF.
string filePath = @"Path and file name for the output export file";
//Create PDF format with appropriate settings
PDFFormat MS_PDF = new PDFFormat()
OutputFileName = filePath,
Resolution = 300,
DoCompressVectorGraphics = true,
DoEmbedFonts = true,
HasGeoRefInfo = true,
ImageCompression = ImageCompression.Adaptive,
ImageQuality = ImageQuality.Best,
LayersAndAttributes = LayersAndAttributes.LayersAndAttributes
//Set up map series export options
MapSeriesExportOptions MS_ExportOptions = new MapSeriesExportOptions()
ExportPages = ExportPages.Custom, //Provide a specific list of pages
CustomPages = "1-3, 5", //Only used if ExportPages.Custom is set
ExportFileOptions = ExportFileOptions.ExportAsSinglePDF, //Export all pages to a single, multi-page PDF
ShowSelectedSymbology = false //Do no show selection symbology in the output
//Export on the worker thread
//Check to see if the path is valid and export
if (MS_PDF.ValidateOutputFilePath())
await QueuedTask.Run(() => layout.Export(MS_PDF, MS_ExportOptions)); //Export to PDF
//Export each page of a map series to an individual TIFF file.
//Create TIFF format with appropriate settings
TIFFFormat TIFF = new TIFFFormat()
Resolution = 300,
ColorMode = TIFFColorMode.TwentyFourBitTrueColor,
HasGeoTiffTags = true,
HasWorldFile = true,
ImageCompression = TIFFImageCompression.LZW
MapSeriesExportOptions MSExportOptions_TIFF = new MapSeriesExportOptions()
ExportPages = ExportPages.All, //All pages
ExportFileOptions = ExportFileOptions.ExportMultipleNames, //Export each page to an individual file using page name as a suffix.
ShowSelectedSymbology = true //Include selection symbology in the output
if (TIFF.ValidateOutputFilePath())
await QueuedTask.Run(() => layout.Export(TIFF, MSExportOptions_TIFF)); //Export to TIFF
