ArcGIS.Desktop.Layouts Namespace / SpatialMapSeries Class
Members Example
    Represents a series of pages that span a range of map extents based on features in a specified index layer.
    Object Model
    SpatialMapSeries ClassRow ClassCIMMapSeries ClassBasicFeatureLayer ClassMapFrame ClassLinearUnit Class
    Syntax
    Public Class SpatialMapSeries
       Inherits MapSeries
    public class SpatialMapSeries : MapSeries
    Example
    Modify an existing map series
      //Modify the currently active map series and changes its sort field and page number field.
      //Note: Must be on QueuedTask.Run
      SpatialMapSeries SMS = layout.MapSeries as SpatialMapSeries; //cast as spatial map series for additional members
      SMS.SortField = "State_Name";
      SMS.SortAscending = true;
      SMS.PageNumberField = "PageNum";
      //Overwrite the current map series with these new settings
      layout.SetMapSeries(SMS);
    Create a new spatial map series
      // This example create a new spatial map series and then applies it to the active layout. This will automatically
      // overwrite an existing map series if one is already present.
      //Note: Must be on QueuedTask.Run;
      //SpatialMapSeries constructor - required parameters
      BasicFeatureLayer indexLyr = map.FindLayers("Countries").FirstOrDefault() as BasicFeatureLayer;
      SpatialMapSeries SMS = MapSeries.CreateSpatialMapSeries(layout, mapFrame, indexLyr, "Name");
      //Set optional, non-default values
      SMS.CategoryField = "Continent";
      SMS.SortField = "Population";
      SMS.ExtentOptions = ExtentFitType.BestFit;
      SMS.MarginType = ArcGIS.Core.CIM.UnitType.PageUnits;
      SMS.MarginUnits = ArcGIS.Core.Geometry.LinearUnit.Centimeters;
      SMS.Margin = 1;
      SMS.ScaleRounding = 1000;
      layout.SetMapSeries(SMS);  //Overwrite existing map series.
    Inheritance Hierarchy
    System.Object
       ArcGIS.Desktop.Layouts.MapSeries
          ArcGIS.Desktop.Layouts.SpatialMapSeries
    Requirements
