You can create multiple map series but a layout can only have one associated map series at a time. There are two basic ways you can work with a map series.
First, you can reference the layout's currently active map series using the MapSeries property on the Layout. This returns a map series CIM definition. Changes can be made and then pushed back to the Layout using the SetMapSeries() method.
Second, you can create a new map series using a constructor like CreateSpatialMapSeries. This will also return a CIM definition that can be modified and pushed back to the Layout using the SetMapSeries() method.
To export a map series you need to contruct an ExportFormat and a MapSeriesExportOptions.
//Modify the currently active map series and changes its sort field and page number field.
//Note: Must be on QueuedTask.Run
SpatialMapSeries SMS = layout.MapSeries as SpatialMapSeries; //cast as spatial map series for additional members
SMS.SortField = "State_Name";
SMS.SortAscending = true;
SMS.PageNumberField = "PageNum";
//Overwrite the current map series with these new settings
layout.SetMapSeries(SMS);
// This example create a new spatial map series and then applies it to the active layout. This will automatically
// overwrite an existing map series if one is already present.
//Note: Must be on QueuedTask.Run;
//SpatialMapSeries constructor - required parameters
BasicFeatureLayer indexLyr = map.FindLayers("Countries").FirstOrDefault() as BasicFeatureLayer;
SpatialMapSeries SMS = MapSeries.CreateSpatialMapSeries(layout, mapFrame, indexLyr, "Name");
//Set optional, non-default values
SMS.CategoryField = "Continent";
SMS.SortField = "Population";
SMS.ExtentOptions = ExtentFitType.BestFit;
SMS.MarginType = ArcGIS.Core.CIM.UnitType.PageUnits;
SMS.MarginUnits = ArcGIS.Core.Geometry.LinearUnit.Centimeters;
SMS.Margin = 1;
SMS.ScaleRounding = 1000;
layout.SetMapSeries(SMS); //Overwrite existing map series.
System.Object
ArcGIS.Desktop.Layouts.MapSeries
ArcGIS.Desktop.Layouts.BookmarkMapSeries
ArcGIS.Desktop.Layouts.SpatialMapSeries
ArcGIS.Desktop.Layouts.ThematicMapSeries
