ArcGIS.Desktop.Layouts Namespace / MapSeries Class / CreateSpatialMapSeries Method
The Layout you will ultimately apply the map series.
The MapFrame that contains the index layer.
A BasicFeatureLayer that include a point, line or polygon attribute table.
A String that represents the Name field in the index layer that should uniquely identify each page.
Example
    Creates a spatial map series. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Shared Function CreateSpatialMapSeries( _
       ByVal layout As Layout, _
       Optional ByVal mapFrame As MapFrame, _
       Optional ByVal indexLayer As BasicFeatureLayer, _
       Optional ByVal nameField As String _
    ) As SpatialMapSeries
    Parameters
    layout
    mapFrame
    indexLayer
    nameField
    Return Value
    Exceptions
    ExceptionDescription
    This method must be called within the lambda passed to QueuedTask.Run.
    Remarks
    This method allows you to create a new spatial map series using a minimum number of required paramters. It returns a CIMSpatialMapSeries object that can be further modified using fine grained properties. To apply the changes to the layout, use the SetMapSeries() method.
    Example
    Create a new spatial map series
      // This example create a new spatial map series and then applies it to the active layout. This will automatically
      // overwrite an existing map series if one is already present.
      //Note: Must be on QueuedTask.Run;
      //SpatialMapSeries constructor - required parameters
      BasicFeatureLayer indexLyr = map.FindLayers("Countries").FirstOrDefault() as BasicFeatureLayer;
      SpatialMapSeries SMS = MapSeries.CreateSpatialMapSeries(layout, mapFrame, indexLyr, "Name");
      //Set optional, non-default values
      SMS.CategoryField = "Continent";
      SMS.SortField = "Population";
      SMS.ExtentOptions = ExtentFitType.BestFit;
      SMS.MarginType = ArcGIS.Core.CIM.UnitType.PageUnits;
      SMS.MarginUnits = ArcGIS.Core.Geometry.LinearUnit.Centimeters;
      SMS.Margin = 1;
      SMS.ScaleRounding = 1000;
      layout.SetMapSeries(SMS);  //Overwrite existing map series.
    Requirements
