ArcGIS.Desktop.Layouts Namespace / SpatialMapSeries Class / ScaleRounding Property
Example
    ScaleRounding Property (SpatialMapSeries)
    Gets or sets the specified value to which the scale rounds.
    Syntax
    public double ScaleRounding {get; set;}
    Public Property ScaleRounding As Double
    Property Value
    Type: Double
    Remarks
    Optional. If not set, no rounding occurs.
    Example
    Create a new spatial map series
      // This example create a new spatial map series and then applies it to the active layout. This will automatically
      // overwrite an existing map series if one is already present.
      await QueuedTask.Run(() =>
        //SpatialMapSeries constructor - required parameters
        BasicFeatureLayer indexLyr = map.FindLayers("Countries").FirstOrDefault() as BasicFeatureLayer;
        SpatialMapSeries SMS = MapSeries.CreateSpatialMapSeries(layout, mapFrame, indexLyr, "Name");
        //Set optional, non-default values
        SMS.CategoryField = "Continent";
        SMS.SortField = "Population";
        SMS.ExtentOptions = ExtentFitType.BestFit;
        SMS.MarginType = ArcGIS.Core.CIM.UnitType.PageUnits;
        SMS.MarginUnits = ArcGIS.Core.Geometry.LinearUnit.Centimeters;
        SMS.Margin = 1;
        SMS.ScaleRounding = 1000;
        layout.SetMapSeries(SMS);  //Overwrite existing map series.
    Requirements
