ArcGIS.Core.Geometry Namespace / GeometryEngine Class / QueryFirstLastM Method
The input polyline.
The first M-value that is not NaN.
The last M-value that is not NaN.
Example
    QueryFirstLastM Method (GeometryEngine)
    Gets the first and last defined M-values in the polyline.
    Syntax
    Public Sub QueryFirstLastM( _
       ByVal polyline As Polyline, _
       ByRef firstM As Double, _
       ByRef lastM As Double _
    public void QueryFirstLastM(
       Polyline polyline,
       out double firstM,
       out double lastM
    Parameters
    polyline
    The input polyline.
    firstM
    lastM
    Return Value
    The first and last defined M-values in the polyline. If the polyline is empty or all the M-values are NaN, then NaN values are returned.
    Exceptions
    ExceptionDescription
    Polyline is null.
    This geometry is not M-Aware.
    Example
    Get the first and last defined M-values in a polyline - QueryFirstLastM
      string json = "{\"hasM\":true,\"paths\":[[[5,4,6],[6,4,5],[8,6,7]],[[0,0,1],[0,1,0],[1,1,-1],[1,0,-2]]]}";
      polyline = PolylineBuilderEx.FromJson(json);
      GeometryEngine.Instance.QueryFirstLastM(polyline, out double firstM, out double lastM);
      // firstM = 6, lastM = -2
      json = "{\"hasM\":true,\"paths\":[[[5,4,null],[6,4,5],[8,6,7]],[[0,0,1],[0,1,0],[1,1,-1],[1,0,null]]]}";
      GeometryEngine.Instance.QueryFirstLastM(polyline, out firstM, out lastM);
      // firstM = 5, lastM = -1
      json = "{\"hasM\":true,\"paths\":[[[5,4,null],[6,4,null],[8,6,null]],[[0,0,null],[0,1,null],[1,1,null],[1,0,null]]]}";
      // firstM and lastM are NaN
      json = "{\"hasM\":true,\"paths\":[]}";
    Requirements
    ArcGIS Pro version: 3.3 or higher.
