ArcGIS.Core.Geometry Namespace / GeometryEngine Class / SetMsAsDistance Method / SetMsAsDistance(Polyline,Coordinate2D,Double,Double,Boolean) Method
The polyline in which to set the M-values.
Determines whether to start measuring distance from the start or end of the polyline part. Measurement starts at the start or end point that is closest to origin.
The value by which the cumulative length of the polyline is multiplied.
The value that is added to the scaled cumulative length of the polyline.
Determines whether distances between parts of the polyline should be ignored or not.
Example
    Sets the M-values of the vertices as scaled and offset distances measured along the polyline.
    Syntax
    Public Overloads Function SetMsAsDistance( _
       ByVal polyline As Polyline, _
       ByVal origin As Coordinate2D, _
       ByVal scale As Double, _
       ByVal offset As Double, _
       ByVal ignoreGaps As Boolean _
    ) As Polyline
    Parameters
    polyline
    origin
    scale
    offset
    ignoreGaps
    Return Value
    Polyline with M-values set. If the input polyline is empty, then it is returned unchanged.
    Exceptions
    ExceptionDescription
    The input polyline is null.
    The geometry is not M-Aware.
    The x-value or y-value of the origin is NaN.
    Example
    Set the M-values of the vertices as scaled and offset distances measured along a polyline - SetMsAsDistance
      string json = "{\"hasM\":true,\"paths\":[[[0,0,1],[3,0,2],[3,6,3],[7,6,4]]],\"spatialReference\":{\"wkid\":4326}}";
      polyline = PolylineBuilderEx.FromJson(json);
      Coordinate2D origin = new(0, 0);
      Polyline outputPolyline = GeometryEngine.Instance.SetMsAsDistance(polyline, origin, 0.5, 1, true) as Polyline;
      // The xy-coordinates of the polyline don't change.
      // The points of outputPolyline are (x, y, m):
      // (0, 0, 1), (3, 0, 2.5), (3, 6, 5.5), (7, 6, 7.5)
      // Measurements will start at the end of the polyline, point (7, 6)
      origin = new Coordinate2D(4, 6);
      // (0, 0, 7.5), (3, 0, 6), (3, 6, 3), (7, 6, 1)
    Requirements
    ArcGIS Pro version: 3.3 or higher.
