ArcGIS.Desktop.Core Namespace / EditingFrameworkExtender Class / OpenExternalTablePane Method / OpenExternalTablePane(PaneCollection,CIMExternalTableView) Method
The external table view for which the table pane will be opened
    Open a table pane for an Item. If a table pane is already open it will be activated. You must be on the UI thread to call this function.
    Syntax
    Public Overloads Shared Function OpenExternalTablePane( _
       ByVal paneCollection As PaneCollection, _
       ByVal externalTableView As CIMExternalTableView _
    ) As IExternalTablePane
    Parameters
    paneCollection
    externalTableView
    Return Value
    Exceptions
    ExceptionDescription
    The externalTableView can not be null.
    The externalTableView must be created by calling the PaneCollection.GetExternalTableView method.
    Table panes cannot be accessed from a thread other than the thread they were created on.
    Requirements
    ArcGIS Pro version: 3.3 or higher.
