ArcGIS.Desktop.Core Namespace / IMetadata Interface / ImportMetadata Method / ImportMetadata(String,MDImportExportOption) Method
Example
    Import metadata
    Syntax
    Overloads Sub ImportMetadata( _
       ByVal catalogPathOrMDUri As String, _
       ByVal importType As MDImportExportOption _
    Parameters
    catalogPathOrMDUri
    importType
    Return Value
    void
    Example
    Item: Updates metadata with the imported metadata - the input path can be the path to an item with metadata, or a URI to a XML file: ImportMetadata
      // the input path can be the path to an item with metadata, or a URI to an XML file
      await QueuedTask.Run(() => metadataItemImport.ImportMetadata(
        @"E:\YellowStone.gdb\MyDataset\MyFeatureClass", MDImportExportOption.esriCurrentMetadataStyle));
    Requirements
