ArcGIS.Desktop.Core Namespace / IMetadata Interface / ImportMetadata Method / ImportMetadata(String,MDImportExportOption,String) Method
Example
    Import metadata
    Syntax
    Parameters
    catalogPathOrMDUri
    importType
    styleSheetPath
    Return Value
    void
    Example
    Item: Updates metadata with the imported metadata: ImportMetadata
      // the input path can be the path to an item with metadata, or a URI to an XML file
      await QueuedTask.Run(() => metadataItemImport.ImportMetadata(
        @"E:\YellowStone.gdb\MyDataset\MyFeatureClass", MDImportExportOption.esriCustomizedStyleSheet,
        @"E:\StyleSheets\Import\MyImportStyleSheet.xslt"));
    Requirements
