ArcGIS.Core.CIM Namespace / CIMKnowledgeGraphQueryDefinition Class / OpenCypherQuery Property
Example
    Gets or sets user defined open cypher query.
    Syntax
    Public Property OpenCypherQuery As String
    public string OpenCypherQuery {get; set;}
    Example
    Add Query Definition
      var newQueryDefinition = new CIMKnowledgeGraphQueryDefinition();
      newQueryDefinition.Name = "Query1";
      newQueryDefinition.ProvenanceBehavior = ProvenanceBehavior.Include;
      newQueryDefinition.OpenCypherQuery = "MATCH (n) RETURN n LIMIT 10\"";     // return the first 10 entities
      // access the currently active knowledge graph investigation view
      KnowledgeGraphInvestigationView activeView = KnowledgeGraphInvestigationView.Active;
      KnowledgeGraphInvestigation investigation = activeView?.Investigation;
      if (investigation != null)
        await QueuedTask.Run(() =>
          // add the new query defintiion
          investigation.AddQueryDefinition(newQueryDefinition);
    Update Query Definition
          // return the first 20 entities
          var newOpenCypherQuery = "MATCH (n) RETURN n LIMIT 20\"";
          // update the open cypher query for a query definition
          investigation.UpdateQueryDefinition("Query1", newOpenCypherQuery);
          // or update other properties
          var myQuery = investigation.GetQueryDefinition("Query1");
          if (myQuery != null)
            myQuery.ProvenanceBehavior = ProvenanceBehavior.Exclude;
            myQuery.OpenCypherQuery = "MATCH (n) RETURN n LIMIT 30\"";
            investigation.UpdateQueryDefinition(myQuery);
    Requirements
    ArcGIS Pro version: 3.3 or higher.
