ArcGIS.Desktop.KnowledgeGraph Namespace / KnowledgeGraphLayerException Class
Members Example
    Managed exception base class for custom ArcGIS.Desktop.Mapping.KnowledgeGraphLayer exceptions
    Syntax
    Public NotInheritable Class KnowledgeGraphLayerException
       Inherits KnowledgeGraphException
       Implements System.Runtime.Serialization.ISerializable
    public sealed class KnowledgeGraphLayerException : KnowledgeGraphException, System.Runtime.Serialization.ISerializable
    Example
    Checking KnowledgeGraphLayerException
      // running on QueuedTask
      var dict = new Dictionary<string, List<long>>();
      dict.Add("person", new List<long>());  //Empty list means all records
      dict.Add("made_call", null);  //null list means all records
      // or specific records - however the ids are obtained
      dict.Add("phone_call", new List<long>() { 1, 5, 18, 36, 78 });
      // make the id set
      var idSet = KnowledgeGraphLayerIDSet.FromDictionary(kg, dict);
      try
        //Create the link chart and show it
        var linkChart = MapFactory.Instance.CreateLinkChart(
                          "KG With ID Set", kg, idSet);
        FrameworkApplication.Panes.CreateMapPaneAsync(linkChart);
      catch (KnowledgeGraphLayerException e)
        // get the invalid named types
        //   remember that the named types are case-sensitive
        var invalidNamedTypes = e.InvalidNamedTypes;
        // do something with the invalid named types
        // for example - log or return to caller to show message to user
    Inheritance Hierarchy
    System.Object
       System.Exception
          ArcGIS.Desktop.KnowledgeGraph.KnowledgeGraphException
             ArcGIS.Desktop.KnowledgeGraph.KnowledgeGraphLayerException
    Requirements
    ArcGIS Pro version: 3.3 or higher.
