Public NotInheritable Class KnowledgeGraphLayer Inherits CompositeLayerWithTables Implements ArcGIS.Desktop.Core.IMetadataInfo, ILayerContainer, ILayerContainerEdit, IMetadataSource, IStandaloneTableContainer, System.ComponentModel.INotifyPropertyChanged
public sealed class KnowledgeGraphLayer : CompositeLayerWithTables, ArcGIS.Desktop.Core.IMetadataInfo, ILayerContainer, ILayerContainerEdit, IMetadataSource, IStandaloneTableContainer, System.ComponentModel.INotifyPropertyChanged
//var kgLayer = MapView.Active.Map.GetLayersAsFlattenedList()
// .OfType<KnowledgeGraphLayer>().FirstOrDefault();
await QueuedTask.Run(() =>
// use the layer directly
KnowledgeGraph datastore = kgLayer.GetDatastore();
// or you can use any of the sub items since
//KnowledgeGraphLayer is a composite layer - get the first
// child feature layer or standalone table
var featlayer = kgLayer?.GetLayersAsFlattenedList()?
.OfType<FeatureLayer>()?.FirstOrDefault();
KnowledgeGraph kg = null;
if (featlayer != null)
using (var fc = featlayer.GetFeatureClass())
kg = fc.GetDatastore() as KnowledgeGraph;
//TODO use KnowledgeGraph
else
//try standalone table
var stbl = kgLayer?.GetStandaloneTablesAsFlattenedList()?
.FirstOrDefault();
if (stbl != null)
using (var tbl = stbl.GetTable())
kg = tbl.GetDatastore() as KnowledgeGraph;
//With a connection to a KG established or source uri available...
//Create a KnowledgeGraphLayerCreationParams
var kg_params = new KnowledgeGraphLayerCreationParams(kg)
Name = "KG_With_All_Types",
IsVisible = false
//Or
var kg_params2 = new KnowledgeGraphLayerCreationParams(new Uri(url))
IsVisible = false
//Call layer factory with map or group layer container.
//A KG layer containing a feature layer and/or standalone table per
//entity and relate type (except provenance) is created
var kg_layer = LayerFactory.Instance.CreateLayer<KnowledgeGraphLayer>(
kg_params, map);
var kg_layer = map.GetLayersAsFlattenedList().OfType<KnowledgeGraphLayer>().FirstOrDefault();
if (kg_layer == null)
return;
if (map.MapType == MapType.LinkChart)
// if map is of MapType.LinkChart then the first level
// children of the kg_layer are of type LinkChartFeatureLayer
var childLayers = kg_layer.Layers;
foreach (var childLayer in childLayers)
if (childLayer is LinkChartFeatureLayer lcFeatureLayer)
var isEntity = lcFeatureLayer.IsEntity;
var isRel = lcFeatureLayer.IsRelationship;
// TODO - continue processing
else if (map.MapType == MapType.Map)
// if map is of MapType.Map then the children of the
// kg_layer are the standard Featurelayer and StandAloneTable
var chidlren = kg_layer.GetMapMembersAsFlattenedList();
foreach (var child in chidlren)
if (child is FeatureLayer fl)
// TODO - process the feature layer
else if (child is StandaloneTable st)
// TODO - process the standalone table
System.Object
ArcGIS.Desktop.Framework.Contracts.PropertyChangedBase
ArcGIS.Desktop.Mapping.MapMember
ArcGIS.Desktop.Mapping.Layer
ArcGIS.Desktop.Mapping.CompositeLayer
ArcGIS.Desktop.Mapping.CompositeLayerWithTables
ArcGIS.Desktop.Mapping.KnowledgeGraphLayer
