Public Function GetIDSet() As KnowledgeGraphLayerIDSet
public KnowledgeGraphLayerIDSet GetIDSet()
| Exception | Description |
| ArcGIS.Core.CalledOnWrongThreadException | This method or property must be called within the lambda passed to QueuedTask.Run. |
//var map = ...
if (map.MapType != MapType.LinkChart)
return;
// find the KG layer
//var kgLayer = map.GetLayersAsFlattenedList()
// .OfType<KnowledgeGraphLayer>().FirstOrDefault();
// find the first LinkChartFeatureLayer in the KG layer
var lcFeatureLayer = kgLayer.GetLayersAsFlattenedList().OfType<LinkChartFeatureLayer>().FirstOrDefault();
if (lcFeatureLayer != null)
return;
await QueuedTask.Run(() =>
// get the ID set of the KG layer
var idSet = kgLayer.GetIDSet();
// get the named object type in the KG that the LinkChartFeatureLayer represents
var typeName = lcFeatureLayer.GetTypeName();
// if there are items in the ID Set for this type
if (idSet.Contains(typeName))
// build a new ID set containing only these records
var dict = idSet.ToOIDDictionary();
var oids = dict[typeName];
var newDict = new Dictionary<string, List<long>>();
newDict.Add(typeName, oids);
var newIDSet = KnowledgeGraphLayerIDSet.FromDictionary(kgLayer.GetDatastore(), newDict);
// now create a new link chart using just this subset of records
MapFactory.Instance.CreateLinkChart("subset LinkChart", kgLayer.GetDatastore(), newIDSet);
// is the set empty?
var isEmpty = idSet.IsEmpty;
// get the count of named object types
var countNamedObjects = idSet.NamedObjectTypeCount;
// does it contain the entity "Species";
var contains = idSet.Contains("Species");
// get the idSet as a dictionary of namedObjectType and oids
var oidDict = idSet.ToOIDDictionary();
var speciesOIDs = oidDict["Species"];
// alternatively get the idSet as a dictionary of
// namedObjectTypes and uuids
var uuidDict = idSet.ToUIDDictionary();
var speciesUuids = uuidDict["Species"];
