ArcGIS.Desktop.Mapping Namespace / KnowledgeGraphLayerIDSet Class / FromDictionary Method / FromDictionary(KnowledgeGraph,Dictionary<String,List<Int64>>) Method
A knowledge graph datastore.
The collection of named types and their corresponding objectIDs.
Example
    Creates a KnowledgeGraphLayerIDSet object from a dictionary of records. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Parameters
    knowledgeGraph
    dict
    Return Value
    Exceptions
    ExceptionDescription
    knowledgeGraph or dict is null.
    Example
    Create a KG Layer containing a subset of Entity and Relate types
      await QueuedTask.Run(() =>
        //To create a KG layer (on a map or link chart) with a subset of
        //entities and relates, you must create an "id set". The workflow
        //is very similar to how you would create a SelectionSet.
        //First, create a dictionary containing the names of the types to be
        //added plus a corresponding list of ids (just like with a selection set).
        //Note: null or an empty list means add all records for "that" type..
        var kg_datamodel = kg.GetDataModel();
        //Arbitrarily get the name of the first entity and relate type
        var first_entity = kg_datamodel.GetEntityTypes().Keys.First();
        var first_relate = kg_datamodel.GetRelationshipTypes().Keys.First();
        //Make entries in the dictionary for each
        var dict = new Dictionary<string, List<long>>();
        dict.Add(first_entity, new List<long>());//Empty list means all records
        dict.Add(first_relate, null);//null list means all records
                                     //or specific records - however the ids are obtained
                                     //dict.Add(entity_or_relate_name, new List<long>() { 1, 5, 18, 36, 78});
        //Create the id set...
        var idSet = KnowledgeGraphLayerIDSet.FromDictionary(kg, dict);
        //Create the layer params and assign the id set
        var kg_params = new KnowledgeGraphLayerCreationParams(kg)
          Name = "KG_With_ID_Set",
          IsVisible = false,
          IDSet = idSet
        //Call layer factory with map or group layer container
        //A KG layer containing just the feature layer(s) and/or standalone table(s)
        //for the entity and/or relate types + associated records will be created
        var kg_layer = LayerFactory.Instance.CreateLayer<KnowledgeGraphLayer>(
            kg_params, map);
    Get and Set a KG Layer IDSet
      var kg_layer = MapView.Active.Map.GetLayersAsFlattenedList()
                      .OfType<KnowledgeGraphLayer>().FirstOrDefault();
      if (kg_layer == null)
        return;
        //Get the existing kg layer id set and convert to a dictionary
        var layer_id_set = kg_layer.GetIDSet();
        var dict = layer_id_set.ToOIDDictionary();//Empty list means all records
        //Create an id set from a dictionary
        var dict2 = new Dictionary<string, List<long>>();
        dict2.Add("Enity_Or_Relate_Type_Name1", null);//Null means all records
        dict2.Add("Enity_Or_Relate_Type_Name2", new List<long>());//Empty list means all records
        dict2.Add("Enity_Or_Relate_Type_Name3",
          new List<long>() { 3, 5, 9, 101, 34 });//Explicit list of ids
                                                 //dict2.Add("Enity_Or_Relate_Type_Name4",
                                                 // new List<long>() { etc, etc });
        //Create the id set
        var idset = KnowledgeGraphLayerIDSet.FromDictionary(kg, dict2);
        //Can be used to create a layer, link chart, append to link chart, etc...
    Create a Link Chart from a query
      //use the results of a query to create an idset. Create the link chart
      //containing just records corresponding to the query results
      var qry = @"MATCH (p1:PhoneNumber)-[r1:MADE_CALL|RECEIVED_CALL]->(c1:PhoneCall)<-" +
                @"[r2:MADE_CALL|RECEIVED_CALL]-(p2:PhoneNumber)-[r3:MADE_CALL|RECEIVED_CALL]" +
                @"->(c2:PhoneCall)<-[r4:MADE_CALL|RECEIVED_CALL]-(p3:PhoneNumber) " +
                @"WHERE p1.FULL_NAME = ""Robert Johnson"" AND " +
                @"p3.FULL_NAME= ""Dan Brown"" AND " +
                @"p1.globalid <> p2.globalid AND " +
                @"p2.globalid <> p3.globalid " +
                @"RETURN p1, r1, c1, r2, p2, r3, c2, r4, p3";
      var queryLinkChart = await QueuedTask.Run(async () =>
        using (var kg_for_lc = kgLayer.GetDatastore())
          var graphQuery = new KnowledgeGraphQueryFilter()
            QueryText = qry
          using (var kg_rc = kg_for_lc.SubmitQuery(graphQuery))
            while (await kg_rc.WaitForRowsAsync())
              while (kg_rc.MoveNext())
                using (var graphRow = kg_rc.Current)
                  // process the row
                  var cnt_val = (int)graphRow.GetCount();
                  for (int v = 0; v < cnt_val; v++)
                    var obj_val = graphRow[v] as KnowledgeGraphNamedObjectValue;
                    var type_name = obj_val.GetTypeName();
                    var oid = (long)obj_val.GetObjectID();
                    if (!dict.ContainsKey(type_name))
                      dict[type_name] = new List<long>();
                    if (!dict[type_name].Contains(oid))
                      dict[type_name].Add(oid);
          //make an ID Set to create the LinkChart
          var idSet = KnowledgeGraphLayerIDSet.FromDictionary(kg_for_lc, dict);
          //Create the link chart and show it
          return MapFactory.Instance.CreateLinkChart(
                   "KG With ID Set", kg_for_lc, idSet);
      await FrameworkApplication.Panes.CreateMapPaneAsync(queryLinkChart);
    Requirements
    ArcGIS Pro version: 3.3 or higher.
