ArcGIS.Desktop.Mapping Namespace / MapView Class / SetCursorPosition Method / SetCursorPosition(MapPoint) Method
The target map point
    Set the cursor position to the specified map point. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Overloads Sub SetCursorPosition( _
       ByVal mapPoint As MapPoint _
    public void SetCursorPosition(
       MapPoint mapPoint
    Parameters
    mapPoint
    Exceptions
    ExceptionDescription
    The viewer is not initialized or is busy.
    Requirements
    ArcGIS Pro version: 3.3 or higher.
