ArcGIS.Core.Data.DDL.Knowledge Namespace / KnowledgeGraphRelationshipTypeDescription Class / KnowledgeGraphRelationshipTypeDescription Constructor / KnowledgeGraphRelationshipTypeDescription Constructor(String)
The name to use for the description object
Example
    Construct a KnowledgeGraphRelationshipTypeDescription with the given name
    Syntax
    Public Function New( _
       ByVal name As String _
    public KnowledgeGraphRelationshipTypeDescription(
       string name
    Parameters
    name
    Exceptions
    ExceptionDescription
    name is invalid
    Remarks
    The name will be used for a new relationship type if the description is used for purposes of creation. Otherwise, it will be used to identify an existing relationship type if the description is used for the purposes of modify or delete.
    Note: An ObjectID and GlobalID property description will automatically be added to the description object within the ArcGIS.Core.Data.DDL.SchemaBuilder. The underlying origin and destination entity id fields present on all relationship types will also be automatically be added.
    Example
    Delete Entity and Relationship Types with SchemaBuilder
      await QueuedTask.Run(() =>
        using (var kg = GetKnowledgeGraph(url))
          var entity_name = "PhoneCall";
          var relate_name = "WhoCalledWho";
          var entityDesc = new KnowledgeGraphEntityTypeDescription(entity_name);
          var relateDesc = new KnowledgeGraphRelationshipTypeDescription(relate_name);
          //Run the schema builder
          try
            SchemaBuilder sb = new(kg);
            sb.Delete(entityDesc);
            sb.Delete(relateDesc);
            //Use the KnowledgeGraph extension method 'ApplySchemaEdits(...)'
            //to refresh the Pro UI
            if (!kg.ApplySchemaEdits(sb))
              var err_msg = string.Join(",", sb.ErrorMessages.ToArray());
              System.Diagnostics.Debug.WriteLine($"Entity/Relate Delete error: {err_msg}");
          catch (Exception ex)
            System.Diagnostics.Debug.WriteLine(ex.ToString());
    Requirements
    ArcGIS Pro version: 3.4 or higher.
