Public NotInheritable Class KnowledgeGraphRelationshipTypeDescription Inherits KnowledgeGraphTypeDescription
public sealed class KnowledgeGraphRelationshipTypeDescription : KnowledgeGraphTypeDescription
await QueuedTask.Run(() =>
using (var kg = GetKnowledgeGraph(url))
var entity_name = "PhoneCall";
var relate_name = "WhoCalledWho";
//Entity Fields
var descs1 =
new List<KnowledgeGraphPropertyDescription>();
descs1.Add(
new KnowledgeGraphPropertyDescription("PhoneOwner", FieldType.String));
descs1.Add(
new KnowledgeGraphPropertyDescription("PhoneNumber", FieldType.String));
descs1.Add(
new KnowledgeGraphPropertyDescription("LocationID", FieldType.BigInteger));
descs1.Add(
new KnowledgeGraphPropertyDescription("DateAndTime", FieldType.Date));
//Relate Fields
var descs2 =
descs2.Add(
new KnowledgeGraphPropertyDescription("Foo", FieldType.String));
descs2.Add(
new KnowledgeGraphPropertyDescription("Bar", FieldType.String));
var includeShape = true;//change to false to omit the shape column
var hasZ = false;
var hasM = false;
KnowledgeGraphEntityTypeDescription entityDesc = null;
KnowledgeGraphRelationshipTypeDescription relateDesc = null;
if (includeShape)
var sr = kg.GetSpatialReference();
var shp_desc = new ShapeDescription(GeometryType.Point, sr)
HasM = hasM,
HasZ = hasZ
entityDesc = new KnowledgeGraphEntityTypeDescription(
entity_name, descs1, shp_desc);
relateDesc = new KnowledgeGraphRelationshipTypeDescription(
relate_name, descs2, shp_desc);
else
entity_name, descs1);
relate_name, descs2);
//Run the schema builder
try
SchemaBuilder sb = new(kg);
sb.Create(entityDesc);
sb.Create(relateDesc);
//Use the KnowledgeGraph extension method 'ApplySchemaEdits(...)'
//to refresh the Pro UI
if (!kg.ApplySchemaEdits(sb))
var err_msg = string.Join(",", sb.ErrorMessages.ToArray());
System.Diagnostics.Debug.WriteLine($"Entity/Relate Create error: {err_msg}");
catch (Exception ex)
System.Diagnostics.Debug.WriteLine(ex.ToString());
System.Object
ArcGIS.Core.Data.DDL.Description
ArcGIS.Core.Data.DDL.Knowledge.KnowledgeGraphTypeDescription
ArcGIS.Core.Data.DDL.Knowledge.KnowledgeGraphRelationshipTypeDescription
