ArcGIS.Core.Data.DDL.Knowledge Namespace / KnowledgeGraphRelationshipTypeDescription Class / KnowledgeGraphRelationshipTypeDescription Constructor / KnowledgeGraphRelationshipTypeDescription Constructor(String,IEnumerable<KnowledgeGraphPropertyDescription>)
The name to use for the description object
The collection of properties for the description object
Example
    Construct a KnowledgeGraphRelationshipTypeDescription with the given name and collection of property descriptions. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Parameters
    name
    propertyDescriptions
    Exceptions
    ExceptionDescription
    name is invalid
    Remarks
    The name will be used for a new relationship type if the description object is used for purposes of creation. Otherwise, it will be used to identify an existing relationship type if the description object is used for the purposes of modify or delete.
    Note: An ObjectID and GlobalID property description will automatically be added to the description object within the ArcGIS.Core.Data.DDL.SchemaBuilder (if these property descriptions were not included in the input propertyDescriptions collection). The underlying origin and destination entity id fields present on all relationship types will also be automatically be added (if they are missing also).
    Example
    Create Entity and Relationship Types with SchemaBuilder
            await QueuedTask.Run(() =>
      using (var kg = GetKnowledgeGraph(url))
        var entity_name = "PhoneCall";
        var relate_name = "WhoCalledWho";
        //Entity Fields
        var descs1 =
            new List<KnowledgeGraphPropertyDescription>();
        descs1.Add(
          new KnowledgeGraphPropertyDescription("PhoneOwner", FieldType.String));
        descs1.Add(
          new KnowledgeGraphPropertyDescription("PhoneNumber", FieldType.String));
        descs1.Add(
          new KnowledgeGraphPropertyDescription("LocationID", FieldType.BigInteger));
        descs1.Add(
          new KnowledgeGraphPropertyDescription("DateAndTime", FieldType.Date));
        //Relate Fields
        var descs2 =
        descs2.Add(
          new KnowledgeGraphPropertyDescription("Foo", FieldType.String));
        descs2.Add(
          new KnowledgeGraphPropertyDescription("Bar", FieldType.String));
        var includeShape = true;//change to false to omit the shape column
        var hasZ = false;
        var hasM = false;
        KnowledgeGraphEntityTypeDescription entityDesc = null;
        KnowledgeGraphRelationshipTypeDescription relateDesc = null;
        if (includeShape)
          var sr = kg.GetSpatialReference();
          var shp_desc = new ShapeDescription(GeometryType.Point, sr)
            HasM = hasM,
            HasZ = hasZ
          entityDesc = new KnowledgeGraphEntityTypeDescription(
            entity_name, descs1, shp_desc);
          relateDesc = new KnowledgeGraphRelationshipTypeDescription(
            relate_name, descs2, shp_desc);
        else
            entity_name, descs1);
            relate_name, descs2);
        //Run the schema builder
        try
          SchemaBuilder sb = new(kg);
          sb.Create(entityDesc);
          sb.Create(relateDesc);
          //Use the KnowledgeGraph extension method 'ApplySchemaEdits(...)'
          //to refresh the Pro UI
          if (!kg.ApplySchemaEdits(sb))
            var err_msg = string.Join(",", sb.ErrorMessages.ToArray());
            System.Diagnostics.Debug.WriteLine($"Entity/Relate Create error: {err_msg}");
        catch (Exception ex)
          System.Diagnostics.Debug.WriteLine(ex.ToString());
    Requirements
    ArcGIS Pro version: 3.4 or higher.
